network problem
19 years 1 month ago #11047
by monsky
network problem was created by monsky
is it possible for 1 computer with a bad NIC to bring down an entire network?
19 years 1 month ago #11050
Replied by TheBishop on topic Bad Computer
Yes, under certain circumstances. Firstly, there is the condition known as jabber where the card's electronics go brain dead and it keeps transmitting all or most of the time, jamming the segment it is on. This is less likely to cripple an entire network these days with our switched infrastructures but it's worh bearing in mind. Another is where the card is partly faulty and so much of what it sends has errors, resulting in loads of retransmissions which soak up the network bandwidth. This might be a genuine fault or a configuration error (e.g duplex mismatch). And while not really a card fault, if there is a misconfiguration a a higher level (e.g duplicate IP address, spanning tree issue, routing anomaly) this can cause a single 'card' to play havoc with your network.
Are you having a specific problem? If so, give us the symptopms and any tests you have undertaken to try to isolate the problem
Time to create page: 0.116 seconds
