Difference between 10baseT and 10baseTX
21 years 5 months ago #1057
by anitagj
Difference between 10baseT and 10baseTX was created by anitagj
Hi all,
i have a basic doubt..
what is the difference between 10BaseT and 10BaseTX.
regards,
anitagj.
regards,
anitagj.
21 years 5 months ago #1067
Replied by Chris on topic Re: Difference between 10baseT and 10baseTX
Anitagj,
Both terms, 10BaseT and 10BaseTX are interchangeable as they are the same.
While 10BaseTX is not that common, there are a few manuals that refer to it. 10BaseT is the term you are most likely to come across when reading network books or related networking sites.
These cable specifications, plus a few more are analysed in detail under our Networking/Cabling section, so please refer to it if you require more information.
