channelised E1 links
- gangadar1234
19 years 7 months ago #10282
by gangadar1234
channelised E1 links was created by gangadar1234
can some body explian what is channelised E1 links
thanks
gangadhar
thanks
gangadhar
19 years 6 months ago #10352
by stefke
Replied by stefke on topic Re: channelised E1 links
A channelized T1 contains 24 individual DS0 channels, each capable of carrying voice or data. The full set of channels has the same speed as a full T1, but the individual channels may be split into voice lines or data lines using a device called a Channel Service Unit/Data Service Unit or CSU/DSU. The CSU/DSU allows the voice channels to be connected to a phone system or PBX. The data lines are then connected to a router serial interface and often are used to provide Internet connectivity.
Greetz,
Stefan
Greetz,
Stefan
19 years 6 months ago #10368
by mew
Replied by mew on topic Re: channelised E1 links
Good job on explaining the channelized T1. I would add that a channelized E1 is the European version and varies slightly as it has 31 DSO's. 30 bearer channels and 1 D channel. The channelized T1 has 23 bearer channels and 1 D channel. These are the Primary Rate Interfaces (PRI) in ISDN services.
