Vlan with dlink unmanaged switch in between two cisco switch
13 years 11 months ago #36841 by bijayswain
Hi
If I connect dlink to a non trunk port it works fine for all pcs connected to dlink switch.
but i have to connect to truck port as my 2960 switch needs vlan .
13 years 11 months ago #36845 by rizin
Would you mind attach your Show run config.txt of 3650 switch. Please do not paste all txt here, attach it with any link.
13 years 11 months ago #36865 by bijayswain
Current configuration : 3288 bytes
version 12.2
no service pad
service timestamps log uptime
hostname ***-3560-Core
enable secret 5 $1$hgTC$LfiTv0GMeqXvtiB.WpBbc/
no aaa new-model
system mtu routing 1500
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode pvst
spanning-tree extend system-id
vlan internal allocation policy ascending
interface FastEthernet0/1
switchport access vlan 20
interface FastEthernet0/2
interface FastEthernet0/3
switchport trunk native vlan 20
interface FastEthernet0/4
interface FastEthernet0/5
duplex full
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
switchport access vlan 40
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
duplex full
interface FastEthernet0/19
duplex full
interface FastEthernet0/20
duplex full
interface FastEthernet0/21
switchport mode access
interface FastEthernet0/22
duplex full
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan20
ip address 172.16.0.1 255.255.0.0
ip helper-address 172.16.0.99
interface Vlan40
ip address 192.1.1.25 255.255.255.0
interface Vlan60
no ip address
interface Vlan80
ip address ************************
interface Vlan100
ip address 192.168.100.1 255.255.255.0
interface Vlan101
ip address 192.168.101.1 255.255.255.0
ip default-gateway 172.16.1.101
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.1.100
ip route 172.17.1.0 255.255.255.0 172.16.0.9
ip*****************************
ip r****************************
control-plane
line con 0
line vty 0 4
password cisco
login
length 0
line vty 5 15
password config t
no login
monitor session 1 source vlan 20
monitor session 1 destination interface Fa0/24
end
13 years 11 months ago #36879 by rizin
switchport mode access duplex full
Make it Auto anywhere you see in duplex full.
Cheers !!!
