UDP/TCP in LAN?
  • truesdq
  • Topic Author
  • Offline
  • Senior Member
  • Senior Member
  • I am simple and have friendly nature
14 years 3 weeks ago #36621 by truesdq
UDP/TCP in LAN? was created by truesdq
UDP and TCP are using in single LAN or not ?
if use then its ok... (would you tell me little about it how using ?)
and :roll: IF not then couldn't be needed this in LAN?
Why?
if We need reliability in LAN then what is Alternative?
simplest
14 years 3 weeks ago #36623 by Nevins
Replied by Nevins on topic Re: UDP/TCP in LAN?
Can we use UDP and TCP on the same Lan?
If you can use UDP and TCP on the same Lan how does that work?
and IF not then couldn't be needed this in LAN? Why?
If you can't use UDP and TCP on the same lan then how would that work?
If we need reliablity in a lan what are the options?
My answer:
UDP and TCP CAN both be used on a single lan. They are not mutually exclusive meaning both TCP and UDP can exist on the same lan segment. Individual transmissions use UDP or TCP however there is generally only one or two frames being transmitted within a single collision domain at any given time in order to avoid collisions on the chosen media. Exceptions in which more then one TCP or UDP message is being transmitted in a single collision domain include actual collisions where 2 or more nodes within a collision domain try to send at the same time creating an actual collision or when full duplex is functioning within a collision domain. Essentially TCP or UDP is chosen based on the data that needs to be transmitted not the network that it's attached to.
Useful Threads
  • truesdq
  • Topic Author
  • Offline
  • Senior Member
  • Senior Member
14 years 1 week ago #36694 by truesdq
Replied by truesdq on topic Re: UDP/TCP in LAN?
well.
TCP and UDP can also be used for the responsibility of the port no/addresses to the target destination ...?
simplest
14 years 1 week ago #36712 by Nevins
I'm honestly not sure what your asking.
Useful Threads
  • truesdq
  • Topic Author
  • Offline
  • Senior Member
  • Senior Member
14 years 6 days ago #36732 by truesdq
i was asking about either TCP or UDP can aslo carry informations of port no. to target destination as appl layer does ?
simplest
