Problem with VLANs
14 years 3 months ago #35899 by Mat7thew
Problem with VLANs was created by Mat7thew
Hey, i seem to be getting dark green lights within my switches, ive set up trunking and vtp server with clients, nothing seems to ping??
password is cisco
secret password should be class
www.2shared.com/file/bWLmkvss/Skills_test.html
Thanks.
N00b
14 years 3 months ago #35910 by Chojin
Replied by Chojin on topic Re: Problem with VLANs
post the configs will do.. .pkt are not my thing :).
14 years 3 months ago #35922 by Mat7thew
Replied by Mat7thew on topic Re: Problem with VLANs
Router
R1#show run
Building configuration...
Current configuration : 1043 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname R1
enable secret 5 $1$mERr$9cTjUIEqNGurQiFU.ZeCi1
interface FastEthernet0/0
no ip address
duplex auto
speed auto
shutdown
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.1
encapsulation dot1Q 1
ip address 172.17.1.1 255.255.255.0
interface FastEthernet0/1.10
encapsulation dot1Q 10
ip address 172.17.10.1 255.255.255.0
interface FastEthernet0/1.20
encapsulation dot1Q 20
ip address 172.17.20.1 255.255.255.0
interface FastEthernet0/1.30
encapsulation dot1Q 30
ip address 172.17.30.1 255.255.255.0
interface FastEthernet0/1.99
encapsulation dot1Q 99 native
ip address 172.17.99.1 255.255.255.0
interface Vlan1
no ip address
shutdown
ip classless
no cdp run
line con 0
password cisco
login
line vty 0 4
password cisco
login
line vty 5 15
password cisco
login
end
Switches
S1#show run
Current configuration : 1498 bytes
version 12.2
hostname S1
no ip domain-lookup
switchport trunk native vlan 99
switchport mode trunk
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface Vlan1
no ip address
shutdown
interface Vlan99
ip address 172.17.99.11 255.255.255.0
ip default-gateway 172.17.99.1
line con 0
logging synchronous
line vty 0 4
password cisco
login
line vty 5 15
password cisco
login
end
S2#show run
Current configuration : 2082 bytes
version 12.2
hostname S2
no ip domain-lookup
switchport access vlan 30
switchport mode access
switchport access vlan 10
switchport access vlan 20
interface Vlan1
no ip address
shutdown
interface Vlan99
ip address 172.17.99.12 255.255.255.0
line con 0
password cisco
logging synchronous
login
line vty 0 4
password cisco
login
line vty 5 15
password cisco
login
end
S3#show run
Current configuration : 1500 bytes
version 12.2
hostname S3
no ip domain-lookup
interface Vlan1
no ip address
shutdown
interface Vlan99
ip address 172.17.99.13 255.255.255.0
line con 0
password cisco
login
line vty 0 4
password cisco
login
line vty 5 15
password cisco
login
end
[/b]
N00b
14 years 2 months ago #36046 by Mat7thew
bump..
N00b
