Cisco ASA 5505 and SBS 2008
14 years 8 months ago #35661
by G-Tech
Dennis E. Pillow
Cisco ASA 5505 and SBS 2008 was created by G-Tech
Help Please,
I am new to Cisco ASA 5505 setup procedures. I have a new 5505 that I am attempting to setup for a Microsoft Small Business Server 2008 network.
The problem I have run into is allowing access to the SBS 2008 server on the standard ports "TCP 25, 80, 443, 987, 1723". This is the only thing I need to do for my test lab setup.
I have been reading and researching this problem for some time now. My Cisco knowledge is very new and this is something I would very much like to acomplish.
I am using the following CISCO Versions:
ASA823-K8.bin
ASDM-634.bin
Can anyone help me with an easy solution using ASDM configuration?
ASA823-K8.bin
ASDM-634.bin
Dennis E. Pillow
14 years 6 months ago #35875
by simd0010
VO
Replied by simd0010 on topic Re: Cisco ASA 5505 and SBS 2008
In docs that's come with your ASA you will find IP and how to get access to ASDM page.
Install java and access to https://192.168.1.1 or like this.
Run wizard and that's it.
Or connect to console and write config by command line... Make sure that some commands are differed and depends from OS (ASA804 or ASA823).
VO
Time to create page: 0.078 seconds
