simple problem, starting to doubt hardware; pix 515e issue
14 years 5 months ago #35571
by RobWMK
simple problem, starting to doubt hardware; pix 515e issue was created by RobWMK
Hello, I've been working with a Cisco Pix 515e running 7.2 for the past while, trying to convince it to route network traffic correctly. After lots of trying this and that, I wanted to get the most basic setup working, so I reset it to factory default configuration and then set up the inside and outside interfaces, the latter going to my normal router and acquiring its IP and default route through DHCP. With this setup, I'd expect a computer on the inside network to access the internet, or failing that, it should be able to access the router's website by ip address, since dns is not set up yet. While I can ping from the firewall itself outwards, it seems unwilling to pass traffic between the two interfaces. I'll put my current running config in with this; am I just missing something important, or is something else going on here? Thanks
PIX Version 7.2(2)
hostname MKPix
domain-name MK
enable password 8Ry2YjIyt7RRXU24 encrypted
names
interface Ethernet0
nameif outside
security-level 0
ip address dhcp setroute
interface Ethernet1
nameif inside
security-level 100
interface Ethernet2
shutdown
no nameif
no security-level
no ip address
interface Ethernet3
shutdown
no nameif
no security-level
no ip address
interface Ethernet4
shutdown
no nameif
no security-level
no ip address
interface Ethernet5
shutdown
no nameif
no security-level
no ip address
ftp mode passive
dns server-group DefaultDNS
domain-name MK
pager lines 24
mtu inside 1500
mtu outside 1500
no failover
asdm image flash:/asdm-523.bin
no asdm history enable
arp timeout 14400
nat (inside) 0 0.0.0.0 0.0.0.0
timeout xlate 3:00:00
http server enable
http 192.168.1.5 255.255.255.255 inside
no snmp-server location
no snmp-server contact
telnet timeout 5
ssh timeout 5
console timeout 0
class-map inspection_default
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
prompt hostname context
Cryptochecksum:fc2972cb2d0da451791bcd78e18c2db3
: end
PIX Version 7.2(2)
hostname MKPix
domain-name MK
names
interface Ethernet0
nameif outside
security-level 0
interface Ethernet1
nameif inside
security-level 100
interface Ethernet2
shutdown
no nameif
no security-level
no ip address
interface Ethernet3
shutdown
no nameif
no security-level
no ip address
interface Ethernet4
shutdown
no nameif
no security-level
no ip address
interface Ethernet5
shutdown
no nameif
no security-level
no ip address
ftp mode passive
domain-name MK
pager lines 24
mtu inside 1500
mtu outside 1500
no failover
arp timeout 14400
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
: end
