Routing Between Subnets
14 years 8 months ago #35028
by trav
Routing Between Subnets was created by trav
Hi All,
I need some help configuring a cisco 877 to route between the following subnets.. I'm a complete novice when it comes to routing such as this so as much help as possible would be appreciated :oops: .
This is all the details I got from the ISP. The internal subnet of the router is 192.168.0.0.
STEP] Subnet size is: 8
Customer static IP info:
Static IP: 202.72.169.***
Starting IP: 58.6.193.*** - Size: 8
[STEP] Subnet size is: 4
[STEP] Allocated subnet.
Starting IP: 58.6.193.*** - Size: 4
- yusufqamri
14 years 8 months ago - 11 years 1 month ago #35102
by yusufqamri
Replied by yusufqamri on topic Re: Routing Between Subnets
lorem ipsum
Last edit: 11 years 1 month ago by yusufqamri.
- yusufqamri
14 years 8 months ago - 11 years 1 month ago #35103
by yusufqamri
lorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsumlorem ipsum
Last edit: 11 years 1 month ago by yusufqamri. Reason: delete
