Packet Tracer- "Dark Green LED"
15 years 1 month ago #33655 by prusso69
Thanks Solo,
You are right, it does not make sense that vlan99 would be on separate subnets. There is no reason for vlan 99 to be involved in layer 3 routing.
So, if i just configure an ip address for vlan 99 on one layer 3 switch and use that ip as the default gateway on both layer 2 switches and any hosts attached to a vlan 99 port, then I should be alright. This way the packet should not jump onto the routed link.
I guess I misunderstood my teacher.
Time to create page: 1.150 seconds
