Router to Router ping failing on Ethernet interface
- CCNALearner
15 years 4 months ago #32906
by CCNALearner
CCNA in progress...
Router to Router ping failing on Ethernet interface was created by CCNALearner
I have one Router R1 attached to R2 on Ethernet but when I ping each other, it fails.
R1:
e0/2 = 192.168.20.1
R2:
e0/0 = 192.168.3.1
R1<
>R2
e0/2
192.168.20.1 e0/0 (192.168.3.1)
What am I missing?
R1:
e0/2 = 192.168.20.1
R2:
e0/0 = 192.168.3.1
R1<
>R2
e0/2
What am I missing?
CCNA in progress...
15 years 4 months ago #32914
by KiLLaBeE
Replied by KiLLaBeE on topic Re: Router to Router ping failing on Ethernet interface
When you configured the IP addresses, what subnet mask did you specify? For easiest configuration, change R2's e0/0 interface to have an IP address of 192.168.20.2 with a subnet mask of 255.255.255.0. Then make sure that R1's e0/2 has the same subnet mask
Also, make sure that you're using a crossover cable to connect the two routers.
Lastly, make sure that both interfaces are in an up/up state when you run "show ip interface brief"
- ToxicAvenger
14 years 8 months ago #35010
by ToxicAvenger
(router)#show ip interface brief
<practically the first command i do when i log into a router>
make sure everything is up up and in the same subnet
Replied by ToxicAvenger on topic Re: Router to Router ping failing on Ethernet interface
R1:
e0/2 = 192.168.20.1
R2:
e0/0 = 192.168.3.1
R1<
>R2
e0/2
What am I missing?
