Report after accessing cisco Lab1
18 years 2 weeks ago #20383
by cozh
Report after accessing cisco Lab1 was created by cozh
Hi Chris & firewall team,
I am so glab, that i am accessing cisco online lab. Now, I would like to report back as follow 2 cases.
1) When i firstly login to Ro1, enable password was cleared. It is correct. Then I try to login to sw1 as firstly there have prompt me Enter password as following. so , i had typed the password "cisco".
Catalyst 1900 Management Console
Copyright (c) Cisco Systems, Inc. 1993-1998
All rights reserved.
Standard Edition Software
Ethernet Address: 00-30-94-61-10-40
PCA Number: 73-3122-04
PCA Serial Number: FAB034435PY
Model Number: WS-C1912-A
System Serial Number: FAB0344S0TS
Power Supply S/N: PHI0331007W
PCB Serial Number: FAB034435PY,73-3122-04
1 user(s) now active on Management Console.
Enter password: *****
2) when i make "copy flash tftp", there showed me "permission denied" as follow:
r1# copy flash tftp
Source filename []? c1600-y-mz.123-22.bin
Address or name of remote host []? 192.168.5.100
Destination filename [c1600-y-mz.123-22.bin]?
TFTP: error code 2 received - 18025
%Error opening tftp://192.168.5.100/c1600-y-mz.123-22.bin (Permission denied)
r1#
As Lastly, I think, my booking time was finished but telnet session wasn't disconnect automatically and i can still connected yet to now onto the lab destination. does can distrub to other member? reply me please. Thank your effort.
I do appreciate!
cozh
r1# copy flash tftp
r1#
I do appreciate!
cozh
17 years 10 months ago #22032
Replied by Chris on topic Re: Report after accessing cisco Lab1
cozh,
Regarding your first question, it's more likely the switch password was not reset correctly, therefore asking you to enter a password before accessing the management console. This should be corrected by now.
Onto your second question, the 'permission denied' error poped up because the file already exists and you are not allowed to overwrite it. This is an easy fix and we'll get to it as soon as possible.
