More of a question than a problem
19 years 10 months ago #8380 by UHSsncmrm
When I submit a new topic and have selected the "notify me of a response" button checked, how am I notified? I may just be stupid or forgetfull, but I don't remember if I've ever been notified!
Thanks Guys! Keep up the good work. I am seeing more and more of Firewall material showing up on all types of Newletters/trade rags/ websites. It's very evident that it is material from Firewall due to the background and coloring. Most places lay reference to or at least cite your site. Good Job Chris, Sahirh, TFS and all involved!
19 years 10 months ago #8381 by DaLight
I noticed this as well. The option's probably been disabled.
19 years 10 months ago #8383 by sahirh
The notification option should send you a personal message when your post has been replied to... there is also an option to have a little popup appear when you sign in and have new PM's...
Though I've not actually used the notification feature, it should be working. If its not, drop us a line.
UHS -- Thanks for the kind words :) the encouragement always helps.
19 years 10 months ago #8400 by UHSsncmrm
Replied by UHSsncmrm on topic Feature
Sahirh, the feature doesn't work.
