Technical Document Sources
19 years 11 months ago #8404 by jaXx
Hi, can anyone refer me to any sources that provide listings of technical documents/journals, mostly in the engineering field?
Cheers!
19 years 11 months ago #8407 by DaLight
I noticed you're from the UK. Are you an IEE member? www.iee.org . Members have access to a wide selection of journals online.
