help! setting up a LAN/Router at home
18 years 11 months ago #14286
by asab
help! setting up a LAN/Router at home was created by asab
hello all, and hope all is well.
been away studying hard on CCNA 2.
need advice and help on this project....
thinking about setting up a small LAN and router at home + firewall.
i'm guessing other members in this forum have setup at home - i need to hear your stories because i want to do it right the first time.
all the advice i can get from you guys is very much welcomed. i hoping this will help me pass this course. practical skills is what i need.
advice on equipment, software – anything and everything.
thank you in advance.
Oh yeah, and my budget for this project is £400 – whatever advice you give must fall within this budget.
18 years 11 months ago #14296
by jwj
-Jeremy-
Replied by jwj on topic Re: help! setting up a LAN/Router at home
Is this going to be used to study for a CCNA? If so, I'd suggest looking at Cisco 2500 series routers. You'll really need more than one router to practice routing configurations, I'd say three would be a good number. Firewalls aren't really on the CCNA, you'll just need to know what they are, but that's it. For a firewall I'd suggest buying an older computer for cheap, loading a Linux distro on it, and use iptables, or if you want something a bit simpler, look at
IPCop
. Dalight is the firewall.cx expert on it, so he can answer most any questions you have about it.
-Jeremy-
