How to detect sniffers within and outside a network.
20 years 4 months ago #6049 by sahirh
"Avoid using VLANs as the sole method of securing access between two subnets. The capability for human error, combined with understanding that VLANs and VLAN tagging protocols were not designed with security in mind, makes their use in sensitive environments inadvisable. When VLANs are needed in security deployments, be sure to pay close attention to the configurations and guidelines mentioned above."
- from
www.cisco.com/warp/public/cc/so/cuso/epso/sqfr/safe_wp.htm
www.fefe.de/switch/
Of course this can be a deployment specific vulnerability. Sorry its been a beer filled Sunday and I'm not really thinking too clearly to analyse the probable attack vectors :). Will hit this again.
20 years 4 months ago #6088 by LostBoy
Thanks all for your help.
However, if I suspect an ip on the network of sniffing, there must be a way of manually detecting it by pinging it and it's mac and then it and a slight mac variation. The idea is that if it's not sniffing it'll reject the ping BUT if it is it'll accept the ping as it's in promiscuous mode.
20 years 4 months ago #6092 by sahirh
?? This doesn't make sense to me.. can you explain what you're saying more clearly or provide a link..
I think what you're looking at is similar to the technique used by L0pht's antisniff.. It works by sending a series of carefully crafted packets in a certain order to a target machine, sniffing the results, and performing timing tests against the target. By measuring timing results and monitoring the target's responses on the network, it can be determined if the target is in promiscuous mode, i.e. sniffing the network.
Here are the technical details on the methods its uses to identify NICs in promisc
www.nsacom.net:1952/txt/Website_Mirrors/...niff/tech-paper.html
20 years 3 months ago #6232 by LostBoy
Thanks for your help. According to Robert Graham:
www.robertgraham.com/pubs/sniffing-faq.html
2.5 How can I detect a packet sniffer?
In theory, it is impossible to detect sniffing programs because they are passive: they only collect packets, they don't transmit anything. However, in practice it is sometimes possible to detect sniffing programs. It is similar to how in theory it is impossible to detect radio/TV receivers, but European countries do it all the time in order to catch people avoiding the radio/TV tax.
A stand-alone packet sniffer doesn't transmit any packets, but when installed non-standalone on a normal computer, the sniffing program will often generate traffic. For example, it might send out DNS reverse lookups in order to find names associated with IP addresses.
Non-standalone packet sniffers are indeed what you want to detect. When crackers/hackers invade machines, they often install sniffing programs. You want to be able to detect this happening.
General Overview of Detection Methods
ping method
Most "packet sniffers" run on normal machines with a normal TCP/IP stack. This means that if you send a request to these machines, they will respond. The trick is to send a request to IP address of the machine, but not to its Ethernet adapter.
To illustrate:
The machine suspected of running the packet sniffer has an IP address 10.0.0.1, and an Ethernet address of 00-40-05-A4-79-32.
You are on the same Ethernet segment as the suspect (remember, the Ethernet is used only to communicate locally on a segment, not remotely across the Internet).
YOU CHANGE THE MAC ADDRESS SLIGHTLY, SUCH AS 00-40-05-A4-79-33.
YOU TRANSMIT AN "ICMP Echo Request" (ping) WITH THE IP ADDRESS AND THIS NEW MAC ADDRESS.
Remember that NOBODY should see this packet, because as the frame goes down the wire, each Ethernet adapter matches the MAC address with their own MAC address. If none matches, then they ignore the frame.
If you see the response, then the suspect wasn't running this "MAC address filter" on the card, and is hence sniffing on the wire.
There are ways defending against this. Now that this technique is widely publicized, newer hackers will enabled a virtual MAC address filter in their code. Many machines (notably Windows) have MAC filtering in drivers. (There is a hack for Windows: most drivers just check the first byte, so a MAC address of FF-00-00-00-00-00 looks like FF-FF-FF-FF-FF-FF (the broadcast address which all adapters accept). However, some adapters implement multicast in such as way that this address will match as a multicast, which is any address whose first byte is an odd number. Thus, this can result in false positives).
This technique will usually work on switched/bridged Ethernets. When switches see an unknown MAC address for the first time, they will "flood" the frame to all segments.
ping method, part 2
The ping method can be enhanced in a number of ways:
Any protocol that generates a response can be used, such as a TCP connection request or a UDP protocol such as port 7 (echo).
Any protocol that might generate an error on the target machine might be used. For example, bad IP header values might be used to generate an ICMP error.
Sometimes a broadcast address (either a "local broadcast" like 255.255.255.255 or a "directed broadcast" like 10.0.0.255) needs to be used in order to bypass software IP address filtering. This then encounters another problem in that many machines do not respond to broadcast requests (responses to broadcasts causes network problems, such as the 'smurf' hack).
ARP method
The ARP method is similar to the ping method, but an ARP packet is used instead. An explanation (in Spanish) is given at www.apostols.org/projectz/neped/ which includes a program called neped to do this detection.
The simplest ARP method transmits an ARP to a non-broadcast address. If a machine responds to such an ARP of its IP address, then it must be in promiscuous mode.
A variation of this technique takes advantage of the fact that machines "cache" ARPs. Each ARP contains the complete information of both the sender as well as the desired target information. In other words, when I send out a single ARP to the broadcast address, I include my own IP-to-Ethernet address mapping. Everyone else on the wire remembers this information for the next few minutes. Therefore, you could do something like sending out a non-broadcast ARP, then a broadcast ping. Anybody who responds to your ping without ARPing you could only have gotten the MAC address from a sniffed ARP frame. (To make double-sure, use a different source MAC address in the ping).
DNS method
Many sniffing programs do automatic reverse-DNS lookups on the IP addresses they see. Therefore, a promiscuous mode can be detected by watching for the DNS traffic that it generates.
This method can detect dual-homed machines and can work remotely. You need to monitor incoming inverse-DNS lookups on the DNS server in your organization. Simply do a ping sweep throughout the company against machines that are known not to exist. Anybody doing reverse DNS lookups on those addresses are attempting to lookup the IP addresses seen in ARP packets, which only sniffing programs do.
This same technique works locally. Configure the detector in promiscuous mode itself, then send out IP datagrams to bad addresses and watch for the DNS lookups.
One interesting issue with this technique is that hacker-based sniffing programs tend to resolve IP addresses as soon as they are found, whereas commercial programs tend to delay resolution until the point where the packet sniffer user views the protocol decodes.
source-route method
Another technique involves configuring the source-route information inside the IP header. This can be used to detect packet sniffers on other, nearby segments.
Create a ping packet, but put a loose-source route to force it by another machine on the same segment. This machine should have routing disabled, so that it will not in fact forward it to the target.
If you get a response, then it is likely the target sniffed the packet off the wire.
In the response, doublecheck the TTL field to find out if it' came back due to sniffing (rather than being routed correctly)
Details:
In loose source-routing, an option is added to the IP header. Routers will ignore the destination IP address and instead forward to the next IP address in the source-route option. This means when you send the packet, you can say "please send packet to Bob, but route it through Anne first".
In this scenario, both "Anne" and "Bob" are on the segment. Anne does not route, and therefore will drop the packet when received. Therefore, "Bob" will only respond if he has sniffed the packet from the wire.
On the off chance that Anne does indeed route (in which case Bob will respond), then the TTL field can be used to verify that Bob responded from routing through Anne, or answering directly.
The decoy method
Whereas the ping and ARP methods only work on the local network, the decoy method works everywhere.
Since so many protocols allow "plain text" passwords, and hackers run sifters looking for those passwords, the decoy method simply satisfies that need. It consists simply of setting up a client and a serve on either side of the network, which the client runs a script to logon to the server using Telnet, POP, IMAP, or some other plain-text protocol. The server is configured with special accounts that have no real rights, or the server is completely virtual (in which case, the accounts don't really exist).
Once a hacker sifts the usernames/passwords from the wire, he/she will then attempt to log on using this information. Standard intrusion detection systems or audit trails can be configured to log this occurance, alerting the fact that a sniffing hacker has found the traffic and attempted to use the information.
www.zurich.ibm.com/~dac/Prog_RAID98/Full...ector.html/index.htm
host method
When hackers break into your systems, they will often leave behind wiretap programs running in the background in order to sniff passwords and user accounts off the wire. These are often imbedded (as a trojan) in other programs, so the only way to find if something like this is running is to query the interfaces to see if they are running in promiscuous mode.
The most technique is to run the program "ifconfig -a". On my computer (Solaris 2.6) the output looks like:
# ifconfig -a
lo0: flags=849<UP,LOOPBACK,RUNNING,MULTICAST> mtu 8232
inet 127.0.0.1 netmask ff000000
hme0: flags=863<UP,BROADCAST,NOTRAILERS,RUNNING,PROMISC,MULTICAST> mtu 1500
inet 192.0.2.99 netmask ffffff00 broadcast 192.0.2.255
ether 8:0:20:9c:a2:98
Of course, the first thing a hacker will do is replace the 'ifconfig' program to hide this. There are other utilities you can download from the net that will query the hardware directly in order to discover this information, or you could run the 'ifconfig' program directly from a CD-ROM distribution.
latency method
This is a more evil method. On one hand, it can significantly degrade network performance. On the other hand, it can 'blind' packet sniffers by sending too much traffic.
This method functions by sending huge quantities of network traffic on the wire. This has no effect on non-promiscuous machines, but has a huge effect on sniffing machines, especially those parsing application layer protocols for passwords. Simply ping the machine before the load and during the load and testing the difference in response time can indicate if the machine is under load.
One problem with this technique is that packets can be delayed simply because of the load on the wire, which may case timeouts and therefore false positives. On the other hand, many sniffing programs are "user mode" whereas pings are responded to in "kernel mode", and are therefore independent of CPU load on a machine, thereby causing false negatives.
TDR (Time-Domain Reflectometers)
A TDR is basically RADAR for the wire. It sends a pulse down the wire, then graphs the reflections that come back. An expert can look at the graph of the response and figure out if any devices are attached to the wire that shouldn't be. They also roughly tell where, in terms of distance along the wire, the tap is located.
This can detect hardware packet sniffers that might be attached to the wire, but which are completely silent otherwise.
TDRs used to be used a lot in the old days of coax Ethernet in order to detect vampire taps, but these days with star topologies, they are used very rarely.
There also exist OTDR equipment, but this is really only for the truely paranoid.
hub lights
You can manually check hub-lights to see if there are any connections you don't expect. It helps to have labeled cables to figure out where (physically) a packet sniffer might be located.
SNMP monitoring
Smart hubs with SNMP management can provide automated monitroning of Ethernet (and other) hubs. Some management consoles will even let you log connections/disconnections to all your ports. If you've configured the system with the information where all the cables terminate, you can sometimes track down where a packet sniffer might be hiding.
Tools to detect packet sniffers
AntiSniff
www.l0pht.com/antisniff/
The most comprehensive sniffer-detection tool.
CPM (Check Promiscuous Mode)
ftp://coast.cs.purdue.edu/pub/tools/unix/cpm/
A tool from Carnegie-Mellon that checks to see if promiscuous mode is enabled on a UNIX machine.
Neped
A tool from The Apostols that detects packet sniffers running on the local segment.
Sentinel
www.packetfactory.net/Projects/sentinel/
cpm (Check Promiscuous Mode)
ftp://ftp.cerias.purdue.edu/pub/tools/unix/sysutils/cpm/
A UNIX tool for checking the promiscuous-mode status of adapters.
Ifstatus
ifstatus
Another UNIX utility that should be run from crontab in order to monitor when adapters are put into promiscuous mode.
20 years 3 months ago #6233 by LostBoy
AND THIS ONE AS WELL:
How to detect other sniffers on the network
Detecting other sniffers on other machines is very difficult (and sometimes impossible). But detecting whether one of the Linux machines is doing the sniffing is possible.
This can be done by exploiting a weakness in the TCP/IP stack implementation of Linux.
When Linux is in promiscuous mode, it will answer to TCP/IP packets sent to its IP address even if the MAC address on that packet is wrong (the standard behavior is that packets containing wrong MAC address will not be answered because the network interface will drop them).
Therefore, sending TCP/IP packets to all the IP addresses on the subnet, where the MAC address contains wrong information, will tell you which machines are Linux machines in promiscuous mode (the answer from those machines will be a RST packet)
While this is far from being a perfect method, it can help discover suspicious activity on a network.
20 years 3 weeks ago #7630 by Nur_AnGel
i am just wondering if anybody can see our e-mail address from using web msn messenger, because i had encounteer somebody who know what is the name of the network i am using and want me to add in his hotmail address to my web msn messenge.
Once i add him in he says that he know the name of the network that i am using as at that time i use my scool network to log in to web msn messenger....The question is is there any program that allow this kind of thing as like the program can chek e-mail of a persom and can identified what is the name of the network that i am using
Am my network have been scan and sniff?....i hope u guys can give me some explanation regarding this issue
