problems with a Cisco ASA 5505
15 years 1 month ago #33889
by gilgamezh
problems with a Cisco ASA 5505 was created by gilgamezh
I am having some problems with a Cisco ASA 5505 Firewall.
apparently the settings are correct, but from the INSIDE network can not ping a public IP.
Perhaps I am missing something that can not see
The WAN connection is connected on port 0 / 1
Lan on 0/0
This is my configuration:
# show running-config
: Saved
ASA Version 8.2(1)
XXXXXXXXX
names
interface Vlan1
nameif inside
security-level 100
ip address 172.20.10.254 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 190.XXX.XXX.134 255.255.255.248
interface Ethernet0/0
interface Ethernet0/1
switchport access vlan 2
interface Ethernet0/2
shutdown
interface Ethernet0/3
shutdown
interface Ethernet0/4
shutdown
interface Ethernet0/5
shutdown
interface Ethernet0/6
shutdown
interface Ethernet0/7
shutdown
ftp mode passive
access-list salida extended permit ip any any
pager lines 24
mtu inside 1500
mtu outside 1500
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 172.20.10.0 255.255.255.0
access-group salida in interface inside
route outside 0.0.0.0 0.0.0.0 190.XXX.XXX.129 1
timeout xlate 3:00:00
timeout tcp-proxy-reassembly 0:01:00
no snmp-server location
no snmp-server contact
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
class-map inspection_default
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
prompt hostname context
Thank you very much for your help!
PS: excuse my language.
Lan on 0/0
: Saved
ASA Version 8.2(1)
XXXXXXXXX
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
ftp mode passive
pager lines 24
mtu inside 1500
mtu outside 1500
arp timeout 14400
telnet timeout 5
ssh timeout 5
console timeout 0
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
15 years 1 month ago #33892
by krik
Christophe Lemaire
www.exp-networks.be/blog/
Replied by krik on topic Re: problems with a Cisco ASA 5505
Config seems ok for me...
Could you try to change your global command as follow :
global (outside) 1 190.XXX.XXX.134
Could you also do a "shwo nat" and "show xlate" after you try to reach an external IP?
Christophe Lemaire
15 years 1 month ago #33921
Replied by S0lo on topic Re: problems with a Cisco ASA 5505
After a quick peek, I also don't see any thing clearly wrong. Try removing those two commands:
You don't need an ACL to let traffic flow from high to low security interfaces. Unless you plan this for some thing else.
I assume you also tried clear xlate command. Can you ping 190.XXX.XXX.134 and 190.XXX.XXX.129 ?
When you ping an outside IP, what message does it give you? is it a Request timed out. or Destination Host Unreachable.
14 years 3 months ago #36133
by sethshawn
Shawn Rocks
Replied by sethshawn on topic Re: problems with a Cisco ASA 5505
It may be worked in my case thanksHi,
Shawn Rocks
14 years 1 week ago #36731
by kiki80
Replied by kiki80 on topic Re: problems with a Cisco ASA 5505
Hello , I have problem with my ASA 5505 .
When I upgrade IOS , I made mistake and deleted flash .... after that I booted from tftp server and get up IOS an disk0: . "Everything" is OK , the router working ....., but when need reboot of ASA 5505 , my router does not boot from disk0:asaXXX.bin and load ROMMON# and I have to set it to boot from tftp Sad .
I followed the commands :
asa5505#boot system disk0:asaXXX.bin
asa5505#reload
after restart
asa5505#sh ver
Cisco Adaptive Security Appliance Software Version 8.2(2)
Device Manager Version 6.2(5)
Compiled on Mon 11-Jan-10 14:19 by builders
System image file is "tftp://192.168.1.1/asa822-k8.bin"
Config file at boot was "startup-config"
ASA5505 up 16 hours 21 mins
Hardware: ASA5505, 512 MB RAM, CPU Geode 500 MHz
Internal ATA Compact Flash, 128MB
BIOS Flash M50FW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
Boot microcode : CN1000-MC-BOOT-2.00
SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
IPSec microcode : CNlite-MC-IPSECm-MAIN-2.04
and every time the router wants to boot from tftp: , that is absurdity Sad .
Do you have any ideas how I repair this problem please ??? Sad
asa5505#reload
after restart
asa5505#sh ver
14 years 1 week ago #36735
kiki80, maybe you forgot to set the configuration register to it's default value of 0x1. You can do it like this:
[code:1]config-register 0x1[/code:1]
Or you can do it from ROMMON like this:
[code:1]confreg 0x1[/code:1]
