Cisco ASA 5505 Configuration help required
15 years 2 months ago #33314 by Girishj22
I am trying to configure asa in my office.This is my first time only so i refered some sites & was trying to configure it.But it is not allowing http traffic to pass.I am posting my config for your reference.Pls help
ASA Version 7.2(4)
hostname Firewall
enable password 6a3buQitz5ajvb6A encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address x.x.x.x 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address x.x.x.x 255.255.255.240
interface Vlan3
shutdown
nameif dmz
security-level 50
no ip address
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
ftp mode passive
dns domain-lookup inside
dns domain-lookup outside
dns server-group DefaultDNS
name-server x.x.x.x
name-server x.x.x.x
access-list 102 extended permit icmp any any echo-reply
access-list 102 extended permit tcp any any eq www
access-list 102 extended permit tcp any any eq telnet
access-list 102 extended permit tcp any any eq smtp
access-list 102 extended permit tcp any any eq pop3
access-list 102 extended permit tcp any any eq ftp
access-list 102 extended permit tcp any any eq ftp-data
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu dmz 1500
no failover
asdm image disk0:/asdm-524.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
route inside 0.0.0.0 0.0.0.0 x.x.x.x 1
timeout xlate 3:00:00
http server enable
http x.x.x.x 255.255.255.0 inside
no snmp-server location
no snmp-server contact
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
class-map inspection_default
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
prompt hostname context
Cryptochecksum:e52521fc670d17fd33f3210e9e6f309c
: end
15 years 2 months ago #33387 by Haxi
Thanks for taking the time to help, I really apprciate it.
Love you all
15 years 2 months ago #33405 by tuanhs
ASA Version 7.2(4)
hostname Firewall
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
interface Vlan3
shutdown
nameif dmz
security-level 50
no ip address
ftp mode passive
name-server x.x.x.x
name-server x.x.x.x
logging enable
mtu inside 1500
mtu outside 1500
mtu dmz 1500
no failover
arp timeout 14400
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
: end
I think that there are something wrong with route command "route inside 0.0.0.0 0.0.0.0 x.x.x.x 1"
15 years 2 months ago #33456 by S0lo
I agree with tuanhs, try to replace the inside keyword with outside. Like this:
route outside 0.0.0.0 0.0.0.0 x.x.x.x 1
Also remember that the x.x.x.x here has to point to the IP at the other side of the outside interface. i.e your ISP IP or whatever is connected there.
Time to create page: 0.274 seconds
