Cisco ASA 5510 firewall configuration problem -- HELP
15 years 3 months ago #32176
by imktz
Cisco ASA 5510 firewall configuration problem -- HELP was created by imktz
Cisco ASA 5510 firewall configuration problem.
Kindly I have the following network set-up:
GATEWAY: 193.220.60.1
DNS PRIMARY: 193.219.193.190
DNS SECONDARY: 193.219.193.191
LAN IP RANGE: 192.168.10.X
Below is the configuration file set-up, can any one help to where I am wrong as the firewall is not working...
ASA Version 7.0(
hostname PRIV_LAN
enable password EwwjZkQXp38H2IKN encrypted
names
dns-guard
interface Ethernet0/0
description PRIV_LAN
nameif outside
security-level 0
ip address 193.220.60.60 255.255.255.0
interface Ethernet0/1
nameif inside
security-level 100
ip address 192.168.1.2 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
ip address 192.168.10.1 255.255.255.0
management-only
ftp mode passive
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu management 1500
asdm image disk0:/asdm-508.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
route outside 0.0.0.0 0.0.0.0 193.220.60.1 1
timeout xlate 3:00:00
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
http server enable
http 192.168.10.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.3-192.168.1.220 inside
dhcpd dns 193.219.193.191
dhcpd lease 3600
dhcpd ping_timeout 50
dhcpd enable inside
class-map inspection_default
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
Cryptochecksum:6e7815b4738b9dffea9d9120f376fe69
ASA Version 7.0(
hostname PRIV_LAN
names
dns-guard
nameif outside
security-level 0
nameif inside
security-level 100
shutdown
no nameif
no security-level
no ip address
nameif management
security-level 100
management-only
ftp mode passive
pager lines 24
mtu outside 1500
mtu inside 1500
mtu management 1500
arp timeout 14400
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd lease 3600
dhcpd enable inside
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
15 years 3 months ago #32217
Replied by S0lo on topic Re: Cisco ASA 5510 firewall configuration problem -- HELP
Are you receiving any errors on the console screen? Can you explain a little on what do you mean by "not working"?
Time to create page: 0.112 seconds
