Help, Easy ASA5505 Port forward
16 years 9 months ago #27261
by ajass
Help, Easy ASA5505 Port forward was created by ajass
I have read dozens of posts on how to configure NAT and ACL and after trying just about everything I still can't get this.
Simple setup, simple need.
I have 1 static IP from ISP, 1 web server, 5 workstations. Workstations are on same VLAN as server.
All I need is for any internet computer to be able to surf my web server using my outside static IP. How hard can this be!? Please help!
Here's what I can do:
1. Surf the internet
2. Surf the web server from inside (10.10.10.5)
Config:
Result of the command: "show running-config"
: Saved
ASA Version 7.2(3)
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 10.10.10.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address xx.xx.45.28 255.255.255.248
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
dns server-group DefaultDNS
access-list INBOUND extended permit tcp any host xx.xx.45.28 eq www
access-list outside_access_in extended permit tcp any host xx.xx.45.28 eq www
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
asdm image disk0:/asdm-523.bin
no asdm history enable
arp timeout 14400
nat-control
global (outside) 1 interface
static (outside,inside) 10.10.10.5 xx.xx.45.28 netmask 255.255.255.255
static (inside,outside) xx.xx.45.28 10.10.10.5 netmask 255.255.255.255
route outside 0.0.0.0 0.0.0.0 xx.xx.45.30 1
timeout xlate 3:00:00
http server enable
http 10.10.10.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd dns 68.87.85.98 68.87.69.146
dhcpd auto_config outside
dhcpd address 10.10.10.2-10.10.10.129 inside
dhcpd enable inside
class-map inspection_default
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
prompt hostname context
Cryptochecksum:c6fd6d43e2230d40103df56b3d4bc161
: end
P.s. When I enter ACL's via command line, they don't show up in the ASDM GUI? Am I missing something here?
I really need this device up and running, any help is greatly appreciated! Thanks!
Config:
: Saved
ASA Version 7.2(3)
hostname ciscoasa
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
arp timeout 14400
nat-control
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd enable inside
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
: end
16 years 8 months ago #27294
by dihas
Replied by dihas on topic Re: Help, Easy ASA5505 Port forward
Remove the following NAT configurations:
and replace with:
static (inside,outside) tcp interface 80 10.10.10.5 80
Then enable your ACL on the outside interface:
access-group INBOUND in interface outside
and replace with:
Time to create page: 0.079 seconds
