Help ASA 5505 Install Problem
- Glenn_ASA5505
16 years 10 months ago #26394
by Glenn_ASA5505
Help ASA 5505 Install Problem was created by Glenn_ASA5505
Help! with initial configuration of ASA 5505. Can't connect to the internet, read the other board suggestions. Probably easy for an expert.
- skepticals
- Elite Member
16 years 10 months ago #26405
by skepticals
Replied by skepticals on topic Re: Help ASA 5505 Install Problem
You didn't really give us anything to go on. Can you post a config?
16 years 10 months ago #26447
by Elohim
Replied by Elohim on topic Re: Help ASA 5505 Install Problem
Set the outside interface for DHCP with setroute (so it will create a default route), assign an ip address to the inside interface. Create a global pool and define which sunetwork will be natted. This is all you need to do to reach the internet.
