Problem with asa 5505
18 years 5 months ago #25600 by ajnabeeaj
well i have a problem with my asa 5505.my isp has given a range of public ip to me 255.255.255.240 and i want to pat a single ip XXX.XXX.XXX.83 out to the internet for the users. in middle there is a router given my isp and its ip address is in the same range. i have a problem when i connect my pc to the firewall with ip address 192.168.20.2 my explorer is not showing my any web site. and i cannot ping inside to outside interface.please help me out i will be really thank full
my runing configuration of asa is
: Saved
: Written by enable_15 at 04:30:58.287 UTC Fri Apr 4 2008
ASA Version 7.2(3)
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.20.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address XX.XXX.XXX.82 255.255.255.240
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
dns server-group DefaultDNS
access-list inside_access_out extended permit ip host 192.168.20.2 host XX.XXX.XXX.82
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
asdm image disk0:/asdm-523.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
global (outside) 1 XX.XXX.XXX.83 netmask 255.255.255.240
access-group inside_access_out out interface inside
timeout xlate 3:00:00
http server enable
http 192.168.20.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.20.2-192.168.20.254 inside
dhcpd enable inside
class-map inspection_default
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
prompt hostname context
Cryptochecksum:5920e90905047af30641aced0ee849d3
: end
18 years 5 months ago #25605 by saidfrh
Replied by saidfrh on topic Re: Problem with asa 5505
Setting PAT and DHCP on ASA5505
dhcpd address 172.16.1.101-172.16.1.132 inside
dhcpd dns x.x.x y.y.y.y
dhcpd wins x.x.x..x
dhcpd enable inside
The above changes your private IPs to the ASA's outside interface public IP.
Since you can not exclude any static private IPs, I set the DHCP range so it does not overlap with any static IPs. You want to assign static IPs to LAN printers, servers.
18 years 5 months ago #25608 by ajnabeeaj
Replied by ajnabeeaj on topic Re: Problem with asa 5505
yes but i want to finish this first i cannot access internet from my pc when i connect to the inside interface. when i connect to the inside and ping the inside interface its getting the reply but when i ping the outside interface there is not reply. i dont knw i am fresher in this field of security i would really appreciate that thank you
18 years 4 months ago #26090 by aphex
Replied by aphex on topic Re: Problem with asa 5505
You havent established a static route.
"route 0.0.0.0 0.0.0.0 gatewayipaddress 1"
18 years 4 months ago #26091 by sp1k3tou
Replied by sp1k3tou on topic Re: Problem with asa 5505
Like stated you need a route command to get to the outside but you will need to use
route outside 0.0.0.0 0.0.0.0 gateway ip
