IPCOP SQUID PROBLEM
18 years 2 months ago #19458 by befree
IPCOP SQUID PROBLEM was created by befree
my name is Roberto.
It's a couple of weeks I start running IPCOP to get how it works.
It's great, simple and useful.
I 've installed some addon including squid 1.4 and urlfilter.
After I selected some url ads zone and start running squid, the web pages included in the ads were blocked and the Ipcop "No authorized" page came up. Great! Then, I made the configuration backup.
I made some changes with copfilter and by then, the squid doesn't block the ads url anymore. I tried to recover the configuration backup but still won't work. I've checked all options but.... nothing to do.
Does anyone know what has happend?
Rgds
Robin
18 years 2 months ago #19473 by DaLight
Replied by DaLight on topic Re: IPCOP SQUID PROBLEM
First of all, did you make a backup from the IPCOP main backup screen or was it a Urlfilter only backup?
Also, did you install copfilter after Urlfilter?
18 years 2 months ago #19482 by befree
Replied by befree on topic Re: IPCOP SQUID PROBLEM
Hi, I did it.
But I've installed copfilter before urlfiletr. Then, urlfilter cannot install itself because it say: There is another squid installed".
Thanks , Robin
18 years 2 months ago #19484 by DaLight
Hi, I did it.
Do you mean it's working now?
18 years 2 months ago #19496 by befree
Hi, I did it.
No, I've reinstalled IPCOP without using copfilter.
Now, it seems to working.
18 years 2 months ago #19498 by DaLight
The order of installation is quite important. You will need to install Urlfilter or Advproxy (if you use it) before Copfilter.
