I need help with history, cookies, cache
18 years 3 months ago #19217
Replied by S0lo on topic Re: I need help with history, cookies, cache
If This user is deleting the cache... etc by means of the usual "Internet options" in the "control panel"
Then you can disable that by disabling the "General" Page in the "Internet options" via a GPO or directly editing the local Group Policy.
To do this type gpedit.msc in the command prompt. Browse to "User Configuration | Administrative Templates | Internet Explorer | Internet Control Panel". Then disable the general page from there.
18 years 3 months ago #19230
by Dove
Yes, As S0lo said you can control it through GPO. But if the user having well knowledge about the system then he can clear everything manualy.....!!!!
There is a way to avoid the manual deletion too.....
we can do this by assingning the folder access permissions to the respective folders like Temp and History folders....
To do this follow this steps..
1. Open the properties window for the respective folders
2. Go to Security
3. Click Advanced
4. Click Effective Permissions
5. There disable the option "Delete" & "Delete Subfolders and Files"
6. After this who are all doesn't having the permissions to delete thos will not able to clear the cookies, history and what ever its on that folder....by manualy or through internt options.
Hope it will works for you....
Dove
Replied by Dove on topic Re: I need help with history, cookies, cache
2. Go to Security
3. Click Advanced
Dove
18 years 3 months ago #19251
by DaLight
Replied by DaLight on topic Re: I need help with history, cookies, cache
I think it's going to be almost impossible to come up with a reliable strategy until eckogirl814 gives more of an idea of the environment, the skill levels of the user and the reasons behind the request.
