Urgent Help with Connecting 2 Pix 515e
19 years 1 month ago #13381
by djjase
Urgent Help with Connecting 2 Pix 515e was created by djjase
19 years 1 month ago #13408
by d_jabsd
Replied by d_jabsd on topic Re: Urgent Help with Connecting 2 Pix 515e
I've done something similar in the past to use a pair of 515e's as a vpn concentrator and a pair of 525s as the primary network firewall.
The 515e's ran 7.0.4 PixOS, the 525s ran 6.3.4.
I set up an interface on each side to be a transit link. I used a /30 address on that link and added routes to each side to reach the other side.
remove the hub connecting the 2 dmzs. you can't dynamically change the default gateway of the hosts on the dmzs, so FW1 people won't be able to get to DMZ2 without first passing through FW2. Connecting the DMZs in this way won't give you any benefit and wastes hardware.
Use the hub for your transit link and be prepared to do a lot of testing. The Pix is not a router, but it does have a little bit of router functionality. You can get it to work. Just pay careful attention to security levels, acls, and routes and you should have it working in no time.
