What is the Best Fire Wall for and ISP?
19 years 4 months ago #12178
by sainfoman
What is the Best Fire Wall for and ISP? was created by sainfoman
Can someone tell me what is the best Fire wall for an ISP?
Will it be the Sonicwall Products? We have tried it and do not seem to work well and cost a arm and a leg
Do any body know the Astaro Fire wall? Hear it is very good and stabile with Spam assistance
Or the AstroFlowGuard
Please help we are desperate and spend a lot of money on the Sonicwall but have to restart the dam thing every once a day.
19 years 4 months ago #12189
by ping
Replied by ping on topic Re: What is the Best Fire Wall for and ISP?
From what sainfoman is saying i can derrive that he is in need of s/w firewall becouse the name he had given came out to be s/w firewall plus a spam guard.
on the other hand i think sainfoman that you should clearify the job firewall inteted to do so that ppls here may get idea and can suggest you.
Cheers..
~Pranav
Cheers..
~Pranav
19 years 4 months ago #12191
by anti-hack
Replied by anti-hack on topic Checkpoint
Hi buddy,
I have used a Checkpoint firewall on Linux. It is pretty secure and fairly easy to maintain and configure. It is also an enterprise level product, as you are talking about an ISP. Not to take anything away from Sonicwall, but expereince on its product proved that it is very effective for a small/medium size organization.
hope i helped,
Regards,
Anti-hack.
hope i helped,
Regards,
Anti-hack.
- TheeGreatCornholio
- Junior Member
19 years 4 months ago #12251
by TheeGreatCornholio
Replied by TheeGreatCornholio on topic Re: What is the Best Fire Wall for and ISP?
Hello all,
I agree for the most part with Anti-hack... except for the CheckPoint part man... sorry - I'm a PIX guy
Anyway - I've been messing around with the SonicWall product line for around 4+ years now... if you have a box that is crashing every day, you are having a unique problem. There are 10's of thousands of those things deployed globally (if not more), working just fine, so you you have one of the following things happening to yours:
- A bad/buggy software image... upgrade the code!
- A hardare problem with the box, where it is causing crashes... open a case with SonicWall and RMA the thing.
- Strage/unsupported configuration (doubtful, but possible)
- Someone on the internet DoS'ing you because of a potential known vulnerability on the code you are running - upgrade the code.
Hopefully you have upgraded the code by now...
If that doesn't help - I'd RMA the thing.
Best of luck to you...
tGc
tGc
- jrolfedrev
19 years 4 months ago #12290
by jrolfedrev
Replied by jrolfedrev on topic Re: What is the Best Fire Wall for and ISP?
You can buy a cheap Netscreen in Ebay.
Time to create page: 0.233 seconds
