IpCop help
19 years 5 months ago #10628 by DaLight
Replied by DaLight on topic Re: IpCop help
put the code in /etc/rc.d/rc.local
19 years 5 months ago #10632 by stanyo
Replied by stanyo on topic Re: IpCop help
It is the same:
iptables v1.2.11: Couldn't find a pattern definition file for bittorent.
iptables v1.2.11: Couldn't find a pattern definition file for winmx.
iptables v1.2.11: Couldn't find a pattern definition file for bittornado...
19 years 5 months ago #10637 by DaLight
Maybe you could try adding the --l7dir /etc/l7-protocols/protocols option to the iptables calls in addition to using the CUSTOMPREROUTING chain instead of the PREROUTING chain. Add the following line after the flush commands for the other custom chains in /etc/rc.d/rc.local:
[code:1]/sbin/iptables -F CUSTOMPREROUTING[/code:1]
Then do a reboot.
The purpose of using the CUSTOM* chains and the associated flush commands is that any changes to rc.local can be updated simply by running:
[code:1]/etc/rc.d/rc.local[/code:1]
16 years 9 months ago #26506 by knoppix
Replied by knoppix on topic ipcop
hey dalight can you help me .........
first time i'm setting up an ipcop router i already installed the software and configure the cards i jus need to know where to go from there
