Campus network design
19 years 5 months ago #10884
by apit
Should you list linux software than can replaced enterprise product and is it possible to cater all the 4000 user?
Replied by apit on topic Re: Campus network design
that mean we have to block this Doom gameYou don't want the students to be able to install Doom 3 and play their buddies online
base on your experience, how did you block the spyware/adawareAlso, spyware and adware could be clogging up your connection with uneeded traffic
If i said below 50K, is it possible(without AP included)I can't really give you a way to implement this without knowing your cost limit
Do you think this is the best method?Or maybe you can make a good Linux box that would serve as the firewall, router, and bandwidth controller?
19 years 5 months ago #10937
by jwj
-Jeremy-
Replied by jwj on topic Re: Campus network design
Lol, I was just meaning keep host security in mind with the Doom 3 example. Adaware, Spy Sweeper, Spybot and more are all popular anti-malware apps. Some even have a corporate version that feature better software updating and management. As far as using a Linux or BSD router/firewall/bandwidth controller, I'm sure it could work with a 4000 user network just fine, but if you're concerned about performance it might not be worth the risk. Perhaps someone with experience could shed some light on this?
-Jeremy-
19 years 5 months ago #11102
by jwj
-Jeremy-
So, would anybody recommend a Linux box to support 4000 users as a router/firewall...? I'd assume so since I've read some articles about how Linux is being for routing, but hands on experience would be great.
-Jeremy-
