Internal Network Slower Than External
19 years 3 months ago #9417
by apit
Internal Network Slower Than External was created by apit
i've problem with my internal network..
here, we have about 20 server including access card server...
people complaint the access card take about 20 second to verify the card..some said the problem come from network itself..user can surf to yahoo without any problem but when using internal network, it much slower than external...do anybody here experince with this kind of problem? what is your seggestion to investigate the problem?
19 years 3 months ago #9419
by DaLight
Replied by DaLight on topic Re: Internal Network Slower Than External
If this problem applies to all internal access and not just this particular server (access card server), it could be a DNS problem. It could be going out to the internet for resolution of internal addresses.
19 years 3 months ago #9423
by apit
Replied by apit on topic Re: Internal Network Slower Than External
so should i check the dns server configuration?
do you suggest i unplugged the dns server and try internal connection?
Time to create page: 0.128 seconds
