Problem with 2 NIC
- ajathsatru
19 years 8 months ago #9303
by ajathsatru
Problem with 2 NIC was created by ajathsatru
I have a two NIC in my machine. One is connected to the main LAN through which i access the internet and the other NIC is connected to the private network. (LAN 2)
When i switch on my machine, i could not access the internet. But if i disable and then enable the LAN connection 2 associated with the private network, i can access the internet.
Can anybody let me know, what might be the problem
19 years 8 months ago #9312
by jwj
-Jeremy-
Replied by jwj on topic Re: Problem with 2 NIC
When you can finally access the internet, are both NIC's enabled? Maybe you can give a little information on how your network is set-up?
-Jeremy-
19 years 8 months ago #9313
by DaLight
Replied by DaLight on topic Re: Problem with 2 NIC
One thing to check is your default gateway. Make sure it's enabled on only one of your NICs, namely, the one connected to the internet.
- ajathsatru
19 years 8 months ago #9320
by ajathsatru
Replied by ajathsatru on topic Re: Problem with 2 NIC
Yes !! Thank you
I have disabled the default gateway for the second NIC and now the problem is solved
