Catalyst 2100 and duplex
21 years 6 months ago #886 by netwarerular
When i setup the 100 mbit port to full duplex, it cant agree with the other side, the speed is about 1 mbit
but if i make it to half duplex it is faster , i has tried to connect it to many switches and Nic´s but it is all the same
/Mattias
Netware Rulez :)
Novell Netware Rulez
netware.mine.nu
//Mattias
21 years 6 months ago #960 by sahirh
Replied by sahirh on topic Re: Catalyst 2100 and duplex
Are you sure the other end of the connection supports 100mbps ? Do the NICs you use support autonegotiation ?
I don't really know if I understood your question correctly
21 years 6 months ago #962 by netwarerular
hey , yes , all nics and switches are 100 mbit
and they support autonegotiation , but they cant be friends with that :)
i need to set it to 100 mbit half duplex
and i dont want to have half duplex
netware.mine.nu
//Mattias
21 years 6 months ago #1011 by dede
Replied by dede on topic Re: Catalyst 2100 and duplex
well i guess you gat no other choice that to have the half duplex done.
