Having Problems upgrading firmware
19 years 10 months ago #8417 by Steve_UK
I'm trying to upgrade the firmware on my BelAir 200 unit but having problems doing so, I start my tftp server(3CDaemon) and in the upload/download directory I put the path
C:\Document and Settings\raj\desktop\BelAir Sofware & Configs\BA200\Rel 3.0.0.2005.03.11\
Once that is done I telnet into the unit and from system type the command
upgrade load remoteip 10.1.1.15 remotepath C:\Document and Settings\raj\desktop\BelAir Sofware & Configs\BA200\Rel 3.0.0.2005.03.11\
I get the following error
Downloading checksum ...
File Download Failed!!
Load upgrade failed. Please retry!!!
I know this is somthing really simple but I cannot figure out what
Anyone have any suggestions ?
P.S the syntax for the command is
upgrade load remoteip <tftpserver> remotepath <tftpSubDir>
19 years 10 months ago #8420 by TheBishop
Replied by TheBishop on topic Problem
Hi Steve_UK
Don't know the BelAir unit personally but I'd have thought that the upgrade command would need not just the path but the full filename of the firmware file complete with the extension:
C:\Document and Settings\raj\desktop\BelAir Sofware & Configs\BA200\Rel 3.0.0.2005.03.11\filename.ext
Otherwise if you had several files in that folder, how would it know which one to load?
Also, and I know it's really obvious, but it should be 'Documents and Settings'
Third suggestion is to use the Browse button in 3CDaemon to set the path rather than typing it in as this eliminates any mistakes
Also unless you are certain about whether your unit is using TFTP or FTP for the update, set up both of them in 3CDaemon just in case
Finally check permissions on the file
