TrendMicro Viruswall Box
20 years 2 months ago #7035
by Lindows
TrendMicro Viruswall Box was created by Lindows
Hey Guys,
I'm planning on building a network in my house.I'm using Trendmicro Internet security 2005 on all the systems. For added network security i was looking at their virus hardware box. I wanted to know has anyone used the" trendmicro virus box" on their network. I'm not sure if its worth purhasing?
Lindows
Lindows
20 years 2 months ago #7065
by sahirh
Replied by sahirh on topic Re: TrendMicro Viruswall Box
Sounds like overkill to me.. a hardware a/v box for a home network. Instead just install good a/v on the hosts (I would sugest Kaspersky if you can get it), and then make sure you're firewalling the Internet connection -- an IPcop implementation would serve you well, plus it has a built in IDS.
20 years 2 months ago #7146
by sahirh
Lemme know how it worked out, I love hearing about home network setups.
That would be the jolly fellow named Chris with the moon shaped avatar, I'm just the friendly neighbourhood security goon 'round these parts
Cheers mate,
Thanks again Admin,
Cheers mate,
