Connecting 2504 to 2600
20 years 2 months ago #6886 by Tony
Connecting 2504 to 2600 was created by Tony
Hello,
I've just bought a couple of 2504 router sand was woundering if I can connection the serial interfaces to a 2600 router??
I'm thinking of buying a 2600 with either WIC1 or WIC2 modules but I'm not sure if the interfaces will connection to the 2500's
Thanks for your help.
20 years 2 months ago #6912 by Chris
Replied by Chris on topic Re: Connecting 2504 to 2600
Tony , you are certainly able to connect them two routers without a problem.
To enasure you dont have any problems, you can simply purchase a 1600 or 2600 with a WIC-1T card and a 'back-to-back' serial cable.
20 years 2 months ago #7015 by Tony
Replied by Tony on topic Re: Connecting 2504 to 2600
Cool! Thanks chris.
