Checkpoint Problem
20 years 2 months ago #6796 by Pedals
Checkpoint Problem was created by Pedals
Has any one come across a problem with Checkpoint, where by when a connection is made using a service (for example RDP) that the firewall blocks the return source port (even though Checkpoint should automatically open the source port).
Pedals
20 years 2 months ago #6809 by TheBishop
Replied by TheBishop on topic Checkpoint
I saw something similar once where the return connection wouldn't work because NAT had been half-implemented, providing a mapping from the outside to the inside but nothing back the other way. If it's not this, check your rules - perhaps you have another rule that is unexpectedly blocking the return part of the conversation
20 years 2 months ago #6810 by Pedals
Replied by Pedals on topic Re: Checkpoint Problem
This problem has also appeared on internal communications between sites that have no NAT implemented.
An RDP connection to SITE A works fine, however and RDP connection to SITE B does not work.
The return source port gets blocked by the drop all rule.
Pealds
