Switch Trouble shooting problem
- chandru_netadmin
21 years 4 months ago #6779
by chandru_netadmin
Switch Trouble shooting problem was created by chandru_netadmin
HI
Can you please any one help me out from this problem
In the cisco switch ,How to see which switch port is connected to which {it should display switch port f0/1 is connected to IP address 192.168.10.5 etc. (IP address of that particular end device )}
please tell me the command to monitor on the switch .
21 years 4 months ago #6780
by Wizmatic
Replied by Wizmatic on topic Re: Switch Trouble shooting problem
You can use this command.
show ip interface brief
or show ip route .
or show ip route .
- chandru_netadmin
21 years 4 months ago #6783
by chandru_netadmin
Replied by chandru_netadmin on topic Re: Switch Trouble shooting problem
Thanks for your answer but it's not giving my desired output
this command is giving static entry ip address of the particular port i want a device which is connected to this ports.
I want which ip address device (hosts or routers ..) is connected to which switch port.
PC's are connected to switch ports , i want one command to see which ip address (Host)is connected to which ports
Like this
IP 192.168.10.5 is connected to switchport f0/1
Ip 192.168.10.16 is connected to switchport f0/2 so somethin like this.
Like this
21 years 4 months ago #6788
by sahirh
Replied by sahirh on topic Re: Switch Trouble shooting problem
Erm... hmm *scratches head*
You should be able to pull that information out of the device using SNMP pretty easily.
21 years 4 months ago #6789
Replied by Chris on topic Re: Switch Trouble shooting problem
I'm not sure if there is a command that will provide the output you require, but you can use:
'show ip arp'
which will provide you the following output:
Cat3550-ITDept2#sh ip arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet 10.0.0.2 61 000b.4668.c080 ARPA Vlan1
Internet 10.0.0.1 142 000b.4668.c080 ARPA Vlan1
Internet 10.0.0.39 140 000b.4668.c080 ARPA Vlan1
Internet 192.168.1.17 - 000f.f7b5.e280 ARPA Vlan1
Internet 192.168.5.21 43 000b.4668.c080 ARPA Vlan1
Internet 192.168.250.1 3 000b.4668.c080 ARPA Vlan1
And then type 'show cdp neig details' to get a full list of other cisco equipment and their IP addresses.
There are a variety of subcommands under 'Show IP arp' , give them a try and see if they do the job for you.
Regards,
'show ip arp'
Regards,
Time to create page: 0.141 seconds
