Having problem with belkin router
20 years 3 months ago #6717
by netmaster
Having problem with belkin router was created by netmaster
I have a belkin f5d7630 uk router , and it is getting hot often, and i need to power down and wait for some time and then start again, Some time the power will not come up !!!!. Is this usual with belkin .....Can any one help me.
20 years 3 months ago #6731
by Cool_Spot
Replied by Cool_Spot on topic Re: Having problem with belkin router
This model has a metal underside, try to keep it off a heat sensitive surface. I know that this model also does seem to run pretty hot compared to many other units.
I'd take it back to the supplier and get it swapped. If you run off a google search, i think you will find alot more people having the same problem. For example...
www.broadbandreports.com/forum/remark,10...0~mode=flat~start=20
20 years 3 months ago #6740
by netmaster
Replied by netmaster on topic Re: Having problem with belkin router
Hi thanks for your information, but this is already a replaced modem !!
20 years 3 months ago #6744
by Cool_Spot
I'm sorry to hear that my friend. Have you tried downloading the latest firmware for the device? It sounds like a design fault, which Belkin need to address.
Sell it on EBAY and buy another model
