Need help with a firewall PIX (any kind lemme know )
21 years 6 months ago #645
by sidd
Need help with a firewall PIX (any kind lemme know ) was created by sidd
Guys if you need any help with the firewall (PIX) just post a message....or the problem ur running into........ maybe I could help you.........
- LittleLebowski
21 years 1 month ago #3015
by LittleLebowski
Replied by LittleLebowski on topic Re: Need help with a firewall PIX (any kind lemme know )
I need help. I just arrived to a company that bought a 515 PIX and we cannot get a VPN going to it. What's more I added a rule and can't delete it. The VP set it up using the wizards. I'll post more once I get response here.
- sillytigger
19 years 6 months ago #10454
by sillytigger
Replied by sillytigger on topic PPTP VPN - yes I know.....
Hi I have a PIX 501 setup and configured to use PPTP for VPN connections (yes bad I know) I can connect using the MS Client on XP Pro. I authenticate and get the VPN, IP etc. however can not see (ping ) the remote site.
Thoughts?
Thoughts?
