504 GateWay TimeOut
- SHEVCHENKO
20 years 3 months ago #6290
by SHEVCHENKO
504 GateWay TimeOut was created by SHEVCHENKO
Hi..
My Name is Abdul
i got a problem here wich Block my Best Site.
i disabled my Firewall, cleared my history, scan with spyware, adware, anti virus, deleted my temp. internet file and cockies.
i dont use a proxy.
this is the site wich am trying to enter
www.milan4ever.com
C:\Documents and Settings\Administrator>ping www.milan4ever.com
Pinging milan4ever.com [67.15.42.16] with 32 bytes of data:
Reply from 67.15.42.16: bytes=32 time=1368ms TTL=47
Reply from 67.15.42.16: bytes=32 time=901ms TTL=47
Reply from 67.15.42.16: bytes=32 time=898ms TTL=47
Reply from 67.15.42.16: bytes=32 time=869ms TTL=47
Ping statistics for 67.15.42.16:
Minimum = 869ms, Maximum = 1368ms, Average = 1009ms
C:\Documents and Settings\Administrator>tracert www.milan4ever.com
Tracing route to milan4ever.com [67.15.42.16]
over a maximum of 30 hops:
1 2717 ms 565 ms 570 ms 10.240.64.1
2 668 ms 656 ms 591 ms 82.167.0.225
3 642 ms 689 ms 623 ms 82.167.0.225
4 605 ms 577 ms 570 ms 134.159.124.233
5 661 ms 574 ms 638 ms i-2-0.per-core02.net.reach.com [202.84.142.25]
6 626 ms 665 ms 648 ms i-5-0.per-core01.net.reach.com [202.84.144.165]
7 757 ms 639 ms 669 ms i-2-0.syd-core04.net.reach.com [202.84.249.226]
8 807 ms 776 ms 905 ms i-1-0.paix-core01.net.reach.com [202.84.249.86]
9 954 ms 877 ms 862 ms 134.159.63.250
10 920 ms 866 ms 910 ms so-4-2-0.mpr3.sjc2.us.above.net [64.125.28.222]
11 942 ms 873 ms 921 ms so-0-0-0.mpr4.sjc2.us.above.net [64.125.30.2]
12 907 ms 883 ms 894 ms so-2-2-0.cr1.dfw2.us.above.net [64.125.29.46]
13 982 ms 899 ms 979 ms so-4-0-0.mpr1.iah1.us.above.net [64.125.31.37]
14 976 ms 876 ms 886 ms so-0-0-0.mpr2.iah1.us.above.net [64.125.31.62]
15 955 ms 885 ms 871 ms t289.216-200-251-162.iah1.us.above.net [216.200.
251.162]
16 912 ms 908 ms 870 ms gphou-66-98-240-10.ev1.net [66.98.240.10]
17 876 ms 867 ms 879 ms gphou-66-98-241-124.ev1.net [66.98.241.124]
18 874 ms 864 ms 900 ms ayeh.micfo.com [67.15.42.16]
Trace complete.
My Name is Abdul
i dont use a proxy.
www.milan4ever.com
251.162]
Trace complete.
20 years 3 months ago #6293
by sahirh
Replied by sahirh on topic Re: 504 GateWay TimeOut
What is the error that you are getting ?
- SHEVCHENKO
20 years 3 months ago #6300
by SHEVCHENKO
Replied by SHEVCHENKO on topic Re: 504 GateWay TimeOut
504 GateWay TimeOut
__
Gateway Timeout
The following error occurred:
[code=GATEWAY_TIMEOUT] A gateway timeout occurred. The server is unreachable. Retry the request.
Please contact the administrator.
__
Gateway Timeout
20 years 3 months ago #6307
by sahirh
Try accessing it through a proxy such as anonymizer.com or one from stayinvisible.com and see if it goes through.
- SHEVCHENKO
20 years 3 months ago #6331
by SHEVCHENKO
thank you mr.sahir
Its work's "gr8" %100
now how can i fix this problem without useing the anonymizer.com..???
