Help needed for network design setup and implementation
19 years 10 months ago #8550 by DaLight
In that case, share the folder containing the program data and give the "students" security group the appropriate permissions (probably read/write/create) to the share.
19 years 10 months ago #8552 by lan2wan
Thanks a lot DaLight. One more question for now.
How about the printer? Can I make the server a print server as well? That way I will connect the printer directly to the server and share it.
Or is there a better way so that all the computers can use t his one printer and probably install it from the desktops.
Lan2Wan
19 years 10 months ago #8564 by DaLight
Best to make the server a print server and share the printer from the server. If you do that the client PCs will pick up the driver directly from the server.
19 years 10 months ago #8586 by lan2wan
Thank you all for your contributions.
Thank you DaLight. I will keep you informed as I go on.
Lan2wan
19 years 10 months ago #8588 by UHSsncmrm
Just a small hint. no need to exclude the devices that DON'T fall into your DHCP scope. So your 2 laptops, servers, printers and access points seem like they don't fall into your DHCP scope and don't need exclusion statements which I don't see in the config but you do mention excluding them.
Good luck and keep us posted!
19 years 10 months ago #8597 by DaLight
No problem, keep me updated lan2wan.
