Problem with cisco 1720 an frame-relay
20 years 3 months ago #6132 by netbaba
Hi to all, i'm paolo from italy :D
I have a problem with a cisco 1720 with frame-relay.
Sometimes it is impossible to navigate in internet, but the PVC between the router and Telecom is mark as active, and with the command debug frame-relay lmi it seems that all are ok.
the result of sh frame-relay pvc, sh frame-relay map and sh frame-relay lmi is ok, so the connection is up! but i can't surf the web! i can re-surf the web only if i reload the router.
Anyone can help me? :?:
:evil:
Admin of Wellage Community
www.wellage.net
20 years 3 months ago #6182 by UHSsncmrm
Can you surf with IP vs URL to validate DNS issues? Maybe paste a show run and show start before your re-load so we can stare and compare?
20 years 3 months ago #6185 by netbaba
I can't surf with ip, too. The run and start config are the same. :cry:
www.wellage.net
