NAT and Frame relay, can they work together?
- kevinbroga
20 years 5 months ago #5657
by kevinbroga
NAT and Frame relay, can they work together? was created by kevinbroga
Could someone tell me if anyway possible for NAT and frame relay and work on the same router. If they can, what kind of syntax do you need to put on the router for it to work correctly.
Kevin
Kevin
20 years 4 months ago #6178
by UHSsncmrm
Replied by UHSsncmrm on topic Re: NAT and Frame relay, can they work together?
Don't quite understand your question, nat is a global config and FR is a Serial Int config, please clarify, they do work together.
- kevinbroga
20 years 4 months ago #6193
by kevinbroga
Replied by kevinbroga on topic Re: NAT and Frame relay, can they work together?
we did get it to work perfectly for our case study we have been donig
20 years 3 months ago #6482
by tsunami
Replied by tsunami on topic Re: NAT and Frame relay, can they work together?
am sorry, from my experience on handling Cisco Routers, i dont think theres a command for that
(config-subif)# ip add 10.1.1.1 255.255.255.0
(config-subif)# ip nat inside
not supported.
we just cant mark the interface for the nat inside or nat outside.
more over as per my knowledge NAT is more suitable for STUB networks and not for multipoint networks
correct me if am wrong
with regards
tsunami
not supported.
with regards
tsunami
20 years 3 months ago #6539
by UHSsncmrm
NAT can be implemented for a number of reasons....on a VPN concentrator to translate publics to privates....To allow vendors to come in on private WAN and not need to add their network space to your core configs....to allow nodes on WAN to use local IP sceme and NAT to your NATIVE IP for security (to pass ACLs.)...to segment LAN and allow access to/from only a few machines to other segments without VLANing in the absence of a layer3 device or dot1q capable IOS.
So you can see that STUB routing isn't the only implementation, there are many creative reasons.
