Help with ACL's please
20 years 5 months ago #5641 by kevinbroga
Research & Development
223.0.0.0/26- Net address
223.0.0.1 -default gateway
223.0.0.2 -vlan address
223.0.0.3 ~ .62 223.0.0.63 -host addresses
255.255.255.192 -subnet mask
The 223.0.0.3 address is saved for the department head, they have access the everything. I have created this access list with the hosts not having FTP or Telnet access, could someone tell me if they will work like this:
access-list 111 permit host 223.0.0.3
access-list 111 permit ip any host 223.0.0.0 0.0.0.255 any eq www
access-list 111 deny ip any host 223.0.0.0 0.0.0.255 any eq ftp
access-list 111 deny ip any host 223.0.0.0 0.0.0.255 any eq telnet
Thanks and any help will be wonderful.
Kevin
20 years 5 months ago #5642 by kevinbroga
I just want to know if I put these on the router, will they work.
Kevin
20 years 5 months ago #5643 by FallenZer0
Kevin
--Looking at the access-list I can say it won't work. The reason being, if you want to filter the network by Application Layer, you MUST choose an entry here that allows you to go up through the OSI model. So, for www, ftp, telnet you must choose *TCP*. If you were to choose IP as you did, you would never leave the Network Layer.
So change the Protocol field entry from IP to TCP.
20 years 5 months ago #5645 by kevinbroga
thanks a whole alot
19 years 10 months ago #8561 by andrewk1
Replied by andrewk1 on topic Kinda off topic
Hi all. You all seem knowledgeble in ACLs, so if I may ask a question? How would one make a ACL that blocks odd ips, such as 192.168.15.1 - 192.168.15.3 ..... , but lets through even ip's aka 192.168.15.2 - 192.168.15.4 etc.... If you can help me, I would be greatly appreciative.
19 years 10 months ago #8570 by stefke
Replied by stefke on topic Re: Help with ACL's please
Greetings,
In reply to fallenZer0 his post:
I was under the presumption that if you specify IP, it included TCP, UDP and ICMP. My guess would be that the ACL's posted by kevinbroga would work.
Greetings,
Stefan
