Requesting help with HA design in network
20 years 9 months ago #4262
by n8
Requesting help with HA design in network was created by n8
I am new to this forum. I hoped I could get some advice from the community.
I have been working on a network for a couple years now and have been using static routes the entire time. I need to migrate my configuration and setup to a high availability environment.
So far I have 1 core router with a single gig fiber link to my global firewall, where I have a gig link connected to my border router. My border router runs BGP with 2 peers. My core router has a gige fiber link to all my l2 stacks. If any one of these devices fail I have an offline device with a matching configuration that I can uplug all cables and plug into, to recover from the failure.
I need to move to a topology where all my secondary devices are active with interconnecting links to the primaries. I believe I can accomplish this by using OSPF and IBGP between my border routers.
If anyone is interested in helping me out, check out my proposal1.jpg to see where I am at now.
www.conclave.us/proposal1.jpg
Here's a summary of my diagram.
Consider that each device with a 1 in its name is active now. All the 2s are my secondary devices which are offline at the moment. I believe I can directly connect the two border routers and run IBGP between them. I can then connect one of my peers to Border 1 and accept full routes. In turn I can directly connect Border 2 to my second peer and accept full routes. If any Border router fails, I still have 1 peer.
The two firewalls (FW#) are interconnected with the Border routers and my core routers, using OSPF. I believe OSPF can choose a default gateway. Correct me if I am wrong.
The two Core routers would be interconnected with OSPF and I would only connect my stacks to one Core router. If my primary core router failed, I could unplug cables and directly connect it to my Core 2 router.
What do you think? Thanks for any advice you can give.
N8
nate@conclave.us
N8
nate@conclave.us
Time to create page: 0.163 seconds
