Dhcp clients not obtaining ip addresses
20 years 8 months ago #4161
by chandak76
Dhcp clients not obtaining ip addresses was created by chandak76
I just set windows server 2003 dhcp and have configured and everything but the client can't seem to connect to the server.Please help.
20 years 8 months ago #4170
by sahirh
Replied by sahirh on topic Re: Dhcp clients not obtaining ip addresses
Have you ensured you have configured the clients to use a dynamically assigned IP address.
Have you checked that your routers are acting as DHCP-relay-agents?
Worst case scenario.. sniff
There is no connection in DHCP, it works over UDP
20 years 8 months ago #4202
by MaXiMuS
Replied by MaXiMuS on topic Re: Dhcp clients not obtaining ip addresses
hey chandak , it would be helpful if you describe your network setup , basically the connectivity between your server and the client which is not receivinf the address...There could be lots of reasons.
1) Is there connectivity between the 2 machines ?? check it out..
2) Is the client correctly configured to receiver addresses ??
3) Is the server configured to assign addresses ??
4) is there a router present between the 2 ??
20 years 8 months ago #4203
by chandak76
Replied by chandak76 on topic Re: Dhcp clients not obtaining ip addresses
Hi,It seems the clients is not communicating with the server,when i try tp ping the server ip i get the destination unreachable.What im tyring to do is to share the internet on a couple of computers.The clients seem to obtain ip addresses that are npt part of the scope.I setup dhcp using these instructions
www.windowsnetworking.com/articles_tutor...indows_2003.html.But
still can not the clients to see the server.Is thgere anything thats missing on these instructions?Have set the clients to obtain an ip address automatically.
20 years 8 months ago #4207
by sahirh
does the IP address it got assigned start with 169
