Catalyst 1900 Home Network
- gsxrboi600
20 years 9 months ago #3987
by gsxrboi600
Catalyst 1900 Home Network was created by gsxrboi600
I'm a cisco novice and I setup a catalyst 1900 in my house. I can ping with in the network but I can't go on th internet (cable modem). Anyone know where i can find info for this? Thanks!
20 years 9 months ago #3994
by MaXiMuS
Replied by MaXiMuS on topic Re: Catalyst 1900 Home Network
ok , so you've put up a catalyst 1900 switch at your home. how many machines have you connected to it ? ( not that it makes any difference to this problem of yours) . You said you are using a cable modem to connect to the internet .... do you plug the modem directly into the switch or do you have a router in between ? As you can ping your internal network , it means the problem is on the outside . First check the port on the switch which you are using to connect to the modem or router.If you can assign an IP to the modem , see if you can ping that . You could even setup a machine bypassing the switch and see if you can access the internet .
- gsxrboi600
20 years 9 months ago #4004
by gsxrboi600
Replied by gsxrboi600 on topic catalyst 1900 home network
I can ping my xbox in the network, but I have not configured the port going to the router. Do I use the routers addy for that port? Thanks!-John
20 years 9 months ago #4005
by sahirh
Replied by sahirh on topic Re: Catalyst 1900 Home Network
You need to configure any device to use the cable modem / router as the default gateway
