Setting up 2 networks with 1 gateway
11 years 8 months ago - 11 years 8 months ago #38223 by Richardbee
Hi Nevins
Thanks again for the help. We only have an unmanaged switch, so, i guess port security is out.
Let me read on the vlans again and try it out. I believe I can only setup vlans using the router with dd-wrt firmware?
Richard
Last edit: 11 years 8 months ago by Richardbee.
11 years 8 months ago - 11 years 8 months ago #38224 by Nevins
Here is the user guide for the WRT54G, I do not believe it supports the features for port security or VLANs as a gateway router.
downloads.linksys.com/downloads/userguid..._UG_WEB_20070529.pdf
I would say it's time to upgrade some hardware but maybe someone else here knows how to make that toaster run like a f-16. What devices do you have to work with? How big is this network?
Useful Threads
Last edit: 11 years 8 months ago by Nevins.
11 years 8 months ago #38227 by Richardbee
Hi Nevins
Managed to set up the guest internet access.
Thanks for your help.
Richard
11 years 8 months ago #38228 by Nevins
No problem what was the solution that you applied?
Useful Threads
11 years 8 months ago #38235 by Richardbee
Hi Nevin
Set up the router using fixed ip, and setup the server firewall to block that particular ip address.
Richard
