Require Network Design for Load Balancing Router
13 years 11 months ago #38149 by sujo
We are having SBS 2003 Server 2 NIC one for Internal and another for External Access.
SBS 2003 DNS server is set as Forwarder
We have 2 ADSL connection Modems and one of the Modem IP Address is set as the Gateway for External NIC card.
We bought Load Balancing Router with 4 LAN ports 2 WAN ports (To connect the modem) to use both the ADSL connection.
Can you please explain how can we configure the Network?
13 years 10 months ago #38151 by sujo
Can anyone tell me which IP address should I use as a default gateway in SBS server External LAN?
LOAD BALANCING ROUTER connection
DSL Modem 1 Connected to WAN 1
DSL Modem 2 Connected to WAN 2
SBS server Internal LAN and External LAN connected to Load Balancing Ethernet ports
