cisco asa 5505 guest network routing issue
12 years 11 months ago - 12 years 11 months ago #37966
by mejor
cisco asa 5505 guest network routing issue was created by mejor
Hello vast internets! I have a 5505 router that I have setup my inside interface on vlan1 to tunnel all traffic back to my main facility. I am now wanting to create a guest network to route that traffic just out the local internet connection. I have created the network but for whatever reason I cannot get out. I tried adding: nat (guest) 1 0.0.0.0 0.0.0.0 with no luck. Any ideas? Please and thanks!
Code:
interface Vlan1
nameif inside
security-level 100
ip address 10.200.50.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address X.X.X.X 255.255.255.248
interface Vlan99
no forward interface Vlan1
nameif guest
security-level 100
ip address 192.168.99.1 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
switchport access vlan 99
interface Ethernet0/6
interface Ethernet0/7
boot system disk0:/asa804-k8.bin
ftp mode passive
clock timezone CST -6
clock summer-time CDT recurring
dns server-group DefaultDNS
domain-name yaya.org
access-list outside_1_cryptomap_1 extended permit ip 10.200.50.0 255.255.255.0 any
access-list inside_nat0_outbound_1 extended permit ip 10.200.50.0 255.255.255.0 any
pager lines 24
logging enable
logging asdm debugging
mtu inside 1500
mtu outside 1500
mtu guest 1500
icmp permit any inside
icmp permit any outside
asdm image disk0:/asdm-61551.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound_1
route outside 0.0.0.0 0.0.0.0 X.X.X.X 1
timeout xlate 3:00:00
aaa authentication ssh console LOCAL
aaa authentication enable console LOCAL
http server enable
http 0.0.0.0 0.0.0.0 outside
http 0.0.0.0 0.0.0.0 inside
no snmp-server location
no snmp-server contact
crypto map outside_map 1 match address outside_1_cryptomap_1
crypto map outside_map 1 set pfs group1
crypto map outside_map 1 set peer JCC
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map 1 set security-association lifetime seconds 28800
crypto map outside_map 1 set security-association lifetime kilobytes 4608000
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 30
ssh version 2
console timeout 0
dhcp-client client-id interface inside
dhcpd lease 172800
dhcpd auto_config outside
dhcpd address 10.200.50.20-10.200.50.100 inside
dhcpd dns 10.200.20.2 10.200.20.14 interface inside
dhcpd lease 172800 interface inside
dhcpd domain yaya.org interface inside
dhcpd enable inside
dhcpd address 192.168.99.10-192.168.99.40 guest
dhcpd dns 208.67.222.222 208.67.220.220 interface guest
dhcpd lease 86400 interface guest
dhcpd enable guest
threat-detection basic-threat
tunnel-group X.X.X.X type ipsec-l2l
tunnel-group X.X.X.X ipsec-attributes
pre-shared-key *
class-map inspection_default
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
Last edit: 12 years 11 months ago by mejor.
