- Thank you received: 10
Issues with Cisco Configuration Professional
13 years 3 weeks ago #37843
by Arani
Issues with Cisco Configuration Professional was created by Arani
Hi all
I'm trying to backup and then upload a configuration file using Cisco Configuration Professional.
But I can't seem to connect to the 1800 router that I am trying to use. If I am on 'Online' mode, it can't connect to the device. When I go on 'Offline' mode, I can connect to the router but the Utilities section is greyed out and I can only see the 'View' section. By forcing the CP to go back to 'Online' mode I can get get the other options enabled but I can't seem to be able to upload any configuration whatsover.
Any help will be appreciated.
13 years 2 weeks ago #37849
Replied by Chris on topic Re: Issues with Cisco Configuration Professional
Arani,
Missed this topic - why bother using CCP mate when you can use the good old CLI method and a TFTP server? I rarely use GUI for Cisco devices - I think they produce more problems than what they are worth
13 years 2 weeks ago #37850
by babis
Replied by babis on topic Re: Issues with Cisco Configuration Professional
Hi i think tha you must try to logon first wirh cli and enable http authentication .
If you enable this and countinious have this problem try to connect with SDM
13 years 2 weeks ago #37851
by Arani
Replied by Arani on topic Re: Issues with Cisco Configuration Professional
Hi Chris
It's not for me. I could flash up the IOS and the config in my sleep using the CLI. It's for a bunch of people who don't have any Cisco knowledge but need to upload a config onto a 1801 router. So I thought I could rustle up something using the CCP which would be simple, using screenshots to show them how it's done.
